- Sep 2, 2013
- 54
It is only meant to measure down to 1.000", note that the scale ends there. There are offset attachments that let it go down the other inch, though then you need to remember to subtract an inch. You can also use a 1-2-3 block or a gage block to take up the difference. I think you also have other problems with the setup as well. It should go down to 1.000", not 1.040". The sliding portion may not be correct for your stand (Frankengage.)
Bob, I thought of that but there's another twist to the story. I bought a package of tools that came with 2 identical height gages. They are both the same way, so I think it is unlikely they are both "frankengages".
