- Jun 21, 2012
- 193
Scuba and Jumps, thank you for your feed back, it is appreciated....Any thoughts on my explanation?
It's definitely your decision to make, and since this would be probably one of the most important components, it makes sense not to cheap out. Good on ya for getting a 1 hp vfd...3 phase motors are cheap and it gives you room to upgrade if you want.
I've used the GS1 class of drives from AutomationDirect.com and had really good results...they are pretty much equivalent to the TECO's. I guess if "waterproof" is equal to not needing an enclosure, then that sounds like a good deal. Enclosures can get expensive (they recommend a lot of internal space for heat dissipation) so if not needed then the extra $50 might be worth it for a drive like this.
