Scuba and Jumps, thank you for your feed back, it is appreciated. I called dealers industrial equipment and asked a lot of questions about the vfd, this is one area that I do not want to cheap out. I explained that I wanted a vfd that I could control with my drum switch, and that it would be in a dusty environment due to the fact that the lathe is in my wood shop, the fm50-101-n4 fits all my needs, it is esentially a fm50-101-c but in a nema4 enclosure, and has push button variable speed too. He said it did not need any other enclosure as it was a waterproof enclosed unit and was the model he recommended for a dusty environment. If I wanted to I could add a remote pot for a dial type variable speed if I wanted to, but I think the up/down push button will be fine. When I am doing wood work in my shop the lathe will be covered. Now I know I could make my own enclosure, and probably save a couple of bucks, but my time is stretched pretty thin these days. So a unit that is pretty much complete with a dust proof enclosure that just needs to be wired and programed is what I am looking for at this time. The extra expense is minor compared to the time it will save me. Also I thought about warranty if the need ever occured. Any thoughts on my explanation?
