Well a friend came over today and helped me get the lathe out of the truck and into my basement, set it up on saw horses and started to tinker with it a little. I pulled all the covers off for an inspection and got everything to turn freely by hand, gearbox works, back gear works, and bull gear engages and disengages freely, all a good sign. I ordered the rebuild kit and manual off of feebay, the 4 oils in a kit, and I am in the negotiation stage with a seller for a belt cover and back gear eccentric and lever assy, as mine is broken off, it works but the lever is broken off. I still need to find a small bull gear cover as that is broken also. The pedestal for the switch mount was broken and I had it tig welded for free from one of the weld shops I deliver to for my work. I have 5 parts loaded into my car for taking to a media blaster. The pedestal I will chemicaly strip as I do not want to get sand and grit into the bearings, I don't want to take it apart if I don't have to. If I give the pully and shaft assy in the pedestal a spin by hand it spins for a long time and makes no noise and has no play, If it aint broke don't fix it. So I am making progress and having a blast doing this, very exciting! The ways show absolutely no wear at all! This lathe must not have seen any commercial use. The ways will probable clean up with a buffing pad and some oil, amazing what I did to them with just my finger. Maybe I'll try some flits or something like it.
