- Apr 8, 2013
- 2,040
I made a dummy barrel stub for a smokeless muzzle loader build so I could have a dress rehersal on fitting the barrel to the action (Savage) and the breech plug to the barrel. As none of my internal bits were small enough to fit the bore, I made a boring bar and an internal threading bit from O1 tool steel. To harden them I heated the bits red hot until they were no longer magnetic using Oxy/acet and then quenched them in oil. I tempered them in an oil bath at 300 degrees F for 30 minutes. The tempering bath was the same one I used for quenching and was held @ 300 DegF via a propane stove and a thermometer normally used for lead bullet casting. When I heated them I did only the cutting end and about 1 inch down the shaft. It went pretty quickly, probably under 2 minutes but I didn't time it. Boring the hole started OK but then didn't sound right so I switched to another boring tool that I inherited from a toolmaker. It worked better than mine. When threading the hole, my 60 degree bit worked great at first but then I noticed on my xslide mounted DI that I was going past the target value for DOC but the thread was still too small. I took out the cutter and resharpened it, then reacquired the thread. It started cutting great again and the thread came out perfect. Do lathe bits made with O1 tool steel dull this quickly or did I not do the heat treatment and subsequent tempering properly? I did file test it and the file just skated across the surface. I can think of 3 possible reasons for my problem but maybe the more experienced members can see this more clearly. They are as follows;
1. Heat treating not done correctly, or slow enough, or long enough?
2. Tempering not done correctly, or maybe shouldn't have been done at all?
3. When I was turning the OD at 1000rpm with carbide, at one point some sparks flew out of the cut. It didn't hurt the cutter and the finish was perfect. Could there be some inclusions in the steel that wouldn't hurt carbide but would dull an O1 threading bit?
Below are some pix.
Below are some pix.
