- Dec 24, 2020
- 1,211
Last week I brought home a Victor 1640 lathe that has a 1976 build date on it. Everything works as it should, and it doesn't seem to have been used much...minimal backlash, ways in great shape, etc. I popped open the headstock cover, the gears all look pristine, and the oil looks clean (amber, no signs of water, etc). Still, I want to drain and refill the headstock for peace of mind.
The side of the headstock is actually marked: "Use Mobil D.T.E. Oil Light" which is ISO32. In the manual it also says to use Mobile D.T.E. Light in the section describing lubrication, but in the lubrication chart just below it lists Mobil D.T.E. Heavy Medium which is ISO 68 and two other brands of equivalent ISO 68 oil. I found a forum reference that someone called Victor and they suggested Shell Turbo T46, which is an ISO 46 oil similar to the Mobil Medium in the named series. Several forum pictures I found of the same machine are marked "Use Mobil D.T.E. Heavy Medium" and the manuals say the same thing in the description and the chart.
I've spent far too much time thinking about this and doing research. My gut tells me the DTE Light would be fine, but it seems pretty light and all the other machines list the ISO 68 oils, so it has me wondering since that's what's in the chart. I'm leaning towards splitting the difference and going with a good AW and R&O ISO 46 and calling it good. A side benefit of that plan is that my Clausing calls for an ISO 46 oil the for headstock so I can use the same oil for both.
Thoughts?
Since everyone loves pics, here are two. It's on the dirty side, but is cleaning up nicely. A funny thing is that the plastic film was still on almost all of the knobs/name plates/etc....oil got behind them, so they looked awful, but pop off the film, wipe the part down and they look pretty nice. I bought it from the second owner. His friend owned a tractor dealership and bought the lathe new for their service department. The seller said he would use if there from time to time and when the owner retired, he bought the lathe. He's a steam power guy who made most of his parts on a nice SB 10L he bought new in 1970, but used the Victor for odd larger parts.
First pic is as it landed and second pic is after less than an hour of cleaning:
Thoughts?
