OK, it's been almost a year, but I finally got around to adding ratcheting capability to my 1T HF and 1/2T Micromark Arbor Presses. As noted
above, I had previously made the tooth removal mod to both, but wanted to go further. I considered the sliding pinion, but that still wasn't the best option IMHO, so I started thinking about using a ratchet wrench. I didn't want to go to the effort of adding a square hole to the end of the pinion
like this; and even though I hadn't seen
this post, I came up with a similar idea: mill a hex on the end of the pinion shaft to accept a standard size socket, then just use said socket with a regular ratchet wrench. While the pinion shaft was out of the frame, I drilled & tapped a hole in the opposite end so I could add a hand wheel to make raising the ram faster.
Holding the pinion from the 1/2T Press in the mill vise with the aid of a copper bar, and
@Doug Gray 's Indexing Plates made the job of milling the 15/16" hex fairly straight forward:
Then to the lathe to drill & tap the other end, using the shaft center to make alignment of the Steady Rest easy:
After everything was back together, it looks pretty good:
Yes, the ratchet is further from the end of the pinion shaft than if I had placed a square hole in the shaft, but only by about 3/8". The gizmo attached to the top of the ram is an accessory from Micromark that provides a depth stop.
I'll post the finished 1T HF Press once a few items arrive this weekend (machining operations were the same, but the hex is 30mm).
