- Nov 2, 2014
- 21
My Harbor Freight/Central Machinery Model 44142 3-in-1 lathe/drill/mill has a habit of blowing capacitors. My motor shop tells me I would be better off with a yankee motor (Baldor) [higher duty cycle] but the Chinese sheaves have a Metric bore. I've looked in catalogs but can't find comparable diameter sheaves to fit the Baldor shaft sizes.
I theory I could bore out the Chinese sheaves and install plugs with the right bore for the Baldor shafts, but I don't have internal keyway capability.
Have any 44142 owners (it's my avatar) made this swap? I'd like to know how you did it and what motors you used.
Thank You!
Edit: I've owned this since 2002 and still have the manual. If anyone needs one, I can scan it.
Thank You!
