Well, the weather was a lot warmer today, so I made time to get into the shop to work on my first batch of brass spacers. Doing a batch of 5 right now. The steps I am following are -
1 - Cut the brass and mill to a 1,25 x 1.25 x .75" blank.
2 - Lay out the hole location for the mounting holes.
3 - Spot drill the hole locations from the receiver side of the blank.
4 - Drill through with a .159 (#21) drill bit
5 - Counterbore the holes to a depth of .625" using a 5/16" drill.
6 - Mill the receiver radius.
7 - Mill the barrel channel
8 - Mill the bottom radius
I made it through #6 today. I'll have a little clean up to do on the mounting holes, such as milling the counterbore to final depth with a 5/16 end mill and enlarging them to the .169 final diameter. After that clean up and polish.
Here are some photos of what I got done today -
