I can. 17 and 18 i have issue with though due to needing the mill. I just dont want to have to many parts half finished and waiting for a millYou'd could pick up D016, D017, and D018. They're all small pieces.
I believe the only thing you would need the mill for would be the dowel hole?I can. 17 and 18 i have issue with though due to needing the mill. I just dont want to have to many parts half finished and waiting for a mill
Never done it... as long as I can machine it with HSS, I don't mind it, though the concern would be whether Shotgun's homemaid hobber will do the work on it.Hey, what does Solidworks say the weight of the worm gear would be in brass? How would you feel about machining Everdur (Silicon Bronze 95% Cu)
Robert
f it gets to that point, you could mail them to me for that feature, and I could assemble them in their parts.
Robert
Edit:
EVERDUR-1010 is a copper-silicon-manganese alloy having the combination of high strength, workability, good machining qualities and corrosion resistance. It is non-magnetic, highly resistant to fatigue, and can be satisfactorily fusion welded.
I can buy 16 lbs of Everdur for $120 but I also have some laying around. Everdur is WAY easier to cast than high zinc brasses.
Robert
