- Apr 29, 2019
- 2,299
I was thinking on the same lines. It would be possible to make a new hobb from a single pointed gear shaft.
Dont mind at all, Just bear in mind that there are compromises made to accommodate the capabilities of the individuals in the project and to keep cost down.
Looking very complex!
Single pointing the worm will be challenging on a light machine due to chatter. Do a test run first maybe? As I recall Erich has a pretty robust machine so it might be fine. What about silver soldering a section of worm over a shaft? If the fit was tight it would be very concentric and a solid joint.
I hope you guys don't mind if I play "devils advocate" and try to find issues with the design. I think that could be helpful before parts are made.
Robert
