Woohoo! This is gettin' real, y'all!
I've got a few questions.
1) The Auxiliary Base has two .089 holes. I assumed they would be for locating pins, but didn't see corresponding holes in the Main Base. What's up with that?
2) The slots for the locating blocks on the bottom of the Main Base. Any reason they can't run the length of the base?
3) The hole for the Trunnion on the Main and Auxiliary Bases would need to be at the exact same height. The numbers on the drawing aren't adding up. I assumed I would clamp the bases together for final boring of the trunnion hole, using the bottom to level set them.
