howdy forum. new member here but long time reader. I've had the Grizzly G0793 G0935 for about a year now. AFAICT it's a clone of the sieg sx3 and it's been a pretty good machine. It has very low hours on it, maybe 15-20, and I've been very kind to it.
A couple of weeks ago it started to stick at very low RPMs so I figured I'd take a look at the spindle bearings. According to Grizzly's part list (I can't link as a new member) and the disassembly doc for the SX3 that I happened upon (on the arceurotrade site), I was expecting to find a tapered roller bearing at the nose and an open cage bearing + thrust bearing at the splines. Well imagine my surprise when I found an angular contact bearing at the nose paired with a single shielded ball bearing at the spline...with no thrust bearing.
Now this appears to be intentional as the preload spacer used on top of the shielded bearing is thick enough to make up for the missing thrust bearing. But the angular contact bearing is indeed shot. it was still well-packed but there are high and low spots. So, I'm left with a few questions:
1) Why was there no thrust bearing? is the presumption that the angular contact bearing can handle the thrust load well enough?
2) could the lack of thrust bearing have caused the (very) premature failure of the ACB?
3) After replacing the ACB, should I add a thrust bearing anyway (coupled with a thinner preload spacer)?
4) Or should I go back to a tapered roller bearing per the (inaccurate) mfg drawings?
I've ordered all the permutations to reassemble this in whatever manner makes the most sense. Meaning I have in hand
- 1 angular contact bearing
- 1 tapered roller bearing
- 1 thrust bearing
- 1 shielded ball bearing
I suppose I could try either/or and see how it feels but I thought to check here first to see if y'all had any guidance. Appreciate your time and expertise
edit: corrected model number.
- 1 thrust bearing
