Grinding wheels for bench grinder?
How much money do you want to spend?
Woodturners Wonder has CBN wheels that don’t break the bank. ~$150 and you can side wheel with em. Plus no AO grit flying around the shop.
A 2x72 belt grinder with a 36g ceramic belt will shape a chunk of HSS in minutes. I had zero experience grinding HSS and with Mikey’s tutorial and a belt grinder I produced great bits very easily.
Found a 6" CBN wheel from Shars that was marked down to $75 to fit my carbide grinder. The AO wheels do throw grit around, but any grinding is a messy process. Keep your grinding out of the same room as your good machinery.
Woodturners Wonder has balancing washers to true up the wheels to your grinder too.
so these days, most wheels wobble. I don't know why. I use shims on the sides of the wheels to help with that. I cut moons out of index cards or paper. it balances the wobble out quite a bit. if you get it close it won't matter.
I would say forget the coarse and fine.
just go for coarse.
The question is what are you grinding. if HSS get a white wheel, if mild steel get a gray wheel.
if only HSS get a white wheel, and a scotchbrite deburring wheel.
I'll have to look at my white wheel, I have both coarse and fine, but don't use the fine. I don't know what grit the coarse is, so I'll look in a while.
If you're using the wheels to create and sharpen HSS lathe tooling I would definitely get both course (60) and fine (100) wheel. The 60 works best for initially creating the tool from a blank, but once you have the basic tool the fine wheel can be used to both finish and resharpen the tool.
I have several grinders in the shop. One has AO wheels for HSS tooling, a second has SO wheels for touching up carbide tools, and I'm in the process of building a version of a long arm buffer with scotchbrite wheels for deburring. In most case I find it's much faster and easier to use a belt grinder than a bench grinder to create and sharpen HSS. In the scheme of things, the 2 bench grinders are some of the least used tools in the shop
The grinder with SO wheels is rarely used. If I'm in a hurry I occasionally use it to touch up a brazed carbide tool. It's messy and doesn't do nearly as good a job as the diamond wheel on the surface grinder.
I haven't looked for diamond or CBN wheels for my surface grinder in quite some time. However, they do occasionally appear on eBay for reasonable prices. I was able to find 2 new 7"diamond wheels and a new 7" CBN wheel for less than $70.00 each.
