Thinking of replacing mine and am wondering if anyone has a recommendation for grit size and/or manufacturer names? I would assume both course and finer grits? I have a 7 inch Metabo bench grinder. The wheels aren't in that bad shape, however I'm getting noticeable wobble at lower rpm and am wondering if these wheels aren't true. (Is this typical with bench grinders? This wobble has been present since I purchased the grinder maybe 5 years ago.) I would expect the wheels to run truer and thought I would check a set of new ones. The grinder appears fairly well constructed. I've checked runout on the shafts and get about 1.5 - 2 thousandths on each shaft. Not sure, but that doesn't seem like it would cause the wobble I'm seeing.
Recently started messing with my rebuilt South Bend 9 and want to begin learning the process of sharpening HSS lathe bits.
Thanks!
Thanks!
