Hello everyone. Ive been on the sidelines for a while and have really enjoyed and learned a good deal from everyone, so thanks for that, I have a problem trying to "break" the cutting edge of my hss lathe bits. I can sharpen them to a point and get good cutting results but the resulting finish is not as good as i would like, it leaves a "phonograph groove type of end result. When I try to slightly round the end of the tooling all I get is chatter and a very rough finish. Ive tried to read everything I can find and I think I am following the methods laid out but to no avail. I wonder if my lathe is to light to sustain the seeming heavier cut ( although I can take a .050 cut with a sharp pointed tool fairly easily).
The lathe I have is an Atlas 6" with the timken bearings and has had very little use. Any help would be welcome.
Thanks,
Rick
Thanks,
Rick
