- Dec 20, 2012
- 9,408
I tell you, Aaron, that Grizzly combo looks like it might just do the trick. If Amazon Prime ever carries it, I might buy one just to get my hands on it. I know for a fact that grinding 1/4" square lathe tools would be no problem on a grinder of this size as long as it meets the criteria listed above.
I would buy a 6" square cornered CBN wheel from Woodturner's Wonders and make a good table for it. Now that I think about it, you could grind the side and end of your tools on the belt and just use the corner of the wheel to grind the rake angles. You would still need a glass platen for longevity but using the wheel for the rake angles makes the obstruction-free thing a non-issue. This makes this grinder even more of a "possible".
I would seriously consider this grinder, Aaron. It is out of stock right now but keep it in mind. I know I will.
