Sorry to revive an old thread but I just recently got the ole Bridgeport up and running and had to chime in and give a big thanks to everyone that helped! I used a 5hp RPC into a 9KVA 220-440 transformer. I wired 120vac directly from the breaker panel to the control side if the machine and everything works! More or less. I found out that my motor controller was bad and changed that out @vista_joe the motor controller in the last picture you posted is the updated version. Now I believe my feed motor is no good. And unfortunately the quill feed motor is no good either but I kinda knew that before I powered it as the motor is cracked right in half.
I've taken some cuts with it boy does it ever hog some metal! But I'm concerned I may have bad spindle bearing or something of the like. However I've never ran one of these specifically so I'm not sure how loud these are supposed to be. I have a woble on my cutter that I measured to be about .003" the bearing top plate was at about 60°C after an hour of heavy cuts and that seems normal to me. I checked the speeds with a laser tach and my lowest speed in high gear is about 1000 and it should go down to about 450 I don't know if the 2 problems are related. And finally the spindle load meter doesn't seem right it free spins at about 85% then when I take a cute it goes down to about 65%. Thanks again for all the help guys!
