Jim,
I don't think the switches from automationdirect will be exact replacements - but I'm really glad you pointed me to this site as there are many goodies there. I'll try to determine the exact set of contacts on the originals - the 22mm switches for 3 positions are very reasonably priced ($15). The knob diameter is larger than the original - don't know the mounting hole size until I remove one of the originals.
Izzy,
I found a reference in a notes file from Bridgeport that indicates the Series II were basically hand built to order and had many options. The two I have are quite different from each other. One has an Erickson Quick Change 40 spindle while the other one has a standard NTMB 40 taper spindle. One can have two separate heads and has at least 7" more clearance between the table and spindle. The motors are of different manufacturers. All of this on machines that were built within 3 years of each other.
Both have power feeds on the knee, x and y axis plus power quill feed. One has a 3 axis Newall DRO.
Now I have to proceed to find all of the places I need to oil (and ensure the automatic oiler is working). I've got a manual that shows this for series I but not series II.
The quill on my working machine really sticks after it has been sitting for minutes - I've read that I need to use lots of wd40 to clean out gunk that may have accumulated on the quill.
Joe
Izzy,
Joe
