Tip
do not let your open tube of loctite fall over and flood your digital vernier.
It wont work after for some reason, it stays locked in the position it was placed down.
I was drilling today with a brand new drill. I noticed excessive swarf was sticking in the flutes of the drill. Cleaning the drill and using cutting oil did not help. I was perplexed.
Turns out the drill was magnetized right out of the package! I de-maged it and problem solved! I would have never guess this, so I am sharing in case you run into this.
It was a Bosch cobalt drill. It actually held up quite well. I drilled about 15" of steel and it still looked brand new and cut on center.
Forget my previous smart ass thread and lets see if we can contribute to the OP's original intent.
I do a lot of machining with small drill bits, cutters etc on my drill / mill.
When chucking up a very small diameter drill bit in a 13 mm three jaw chuck it is very easy to get the chuck to tighten down on the bit when it is between just two jaws and not centered among the three.
Turning on the press without first doing a manual sweep can break the bit or damage the work piece.
Always rotate the chuck after tightening by hand to check clearance.
