- Jan 25, 2015
- 2,554
I despise my carbide burrs for the same reasons. There's absolutely no way to not get a couple metal splinters when using them. They even penetrate clothing to find the "liquid red" inside. Even weeks later, I'm still finding steel needles all over. Sometimes on the floor, sometimes on the bench and sometimes when I put on a shirt weeks later (after several washings) and I still get "poked". I actually root through my dresser now for shirts I can throw away after using the carbide burrs rather than trying to wash them. Probably better for the washer too.....My lesson for May:
I was welding up the front brush guard of my church's tractor, and needed to smooth my craptastic 6011 stick welding down a bit. Couldn't get a flap sander into the spot, so I used a carbide burr on a die grinder.
Carbide burr grinders make 2.4 bazillion needle-sharp chips every second and a half. They are like living nanobots seeking to embed themselves into the nearest human as part of a plan to take over the world. The mistake is: Don't use welding jig magnets when making those sorts of chips. It's been a couple of weeks, and I'm still digging chips out of my fingers using my very expensive watchmaker tweezers. The chips stand straight up on the magnet with the sharpest point aimed out, turning the magnet into a chia-pet porcupine. Next time, the magnets get moved to a different building and the burr gets used only when the chips can be aimed right into a shop vac.
But there was a good trick I learned: The kind of duct tape that uses that worthless gooey adhesive that has no redeeming qualities whatsoever works pretty well at pulling sharp chips off a magnetic welding jig.
Rick "20x microscope and sharp tweezers getting a lot of use this week" Denney
There's times when nothing else will do and you're forced to use the burr, but I do everything in my power to NOT have to use them.....
