G0704 CNC AC Servo Rebuild (Picture Heavy)
Marardos, your work has been incredible. I had a G0704 for a while before I sold to a friend and bought my PM45M-CNC. I would NEVER have thought anyone could supercharge the G0704 the way you have. Just Fantastic.
Thank you so much! I'm having a lot of fun. I just really want an easy to use and reliable machine that I can turn on a never have to fiddle with to make good looking parts. Next steps will be figuring out how to advertise since I haven't done any real work since I last moved. I love small customer jobs, especially when I get to work on the design/engineering with them.
Lots of small companies out there do short-run production. www.protoshapes.com is a company run by my wife's brother. He does low-volume production urethane parts. Quite a variety of products from air nozzles to clear the glass on deep-sea diving helmets, to air guns to blow off cars at car washes, dice with the pips out for the blind, speaker horns, prototype tail lamps for the auto industry, etc. He's got a local guy with a CNC mill, 3-D printer and stereo-lithography for making models to cast the urethane dies. You're in an industrial area and should be able to find some similar companies.
Bruce
Bruce, Thanks for the ideas! I think once we are all done with wedding planning (~June) then I will start seriously trying to get some work. Everything previously has been word of mouth (mostly college startup type stuff).
On the topic of the CNC, I have been having some issues with the spindle whenever it is accelerating, changing speeds, or decelerating to a stop. Not sure if it is a wiring, Mach, or ethernet smoothstepper issue, but the servo receives delayed or missing steps which cause significant clunking in the drivetrain and occasionally a drive fault. I have a workaround to limit the servo acceleration at the drive level but this isn't the best fix.
I have a support ticket in with Warp9TD (whose support is A+) so it will be interesting to see where it goes.
Few trends showing what should be a smooth ramp in commanded speed of the spindle motor, but has a dip back to 0rpm which causes aggressive jerking of the spindle:
Note that the graphs are inverted to -5000 rpm due to the drive polarity, but it doesn't make a difference.
291397
291398
291399
OK, chucks made it in last week. I have mixed feelings about the quality of the product, but I don't regret buying them. Here is my best attempt at an unbiased review. I will make some comparisons between the Tormach TTS tools I have as well as my previously purchased non-ATC chucks.
Shipping and Packaging: Tools arrived within 3 week days from me placing my order via USPS. They were placed inside a double bagged padded Priority Mail envelopes. Each chuck was wrapped in a plastic bag with rust inhibitor and then inside a telescoping plastic tube that tools usually come in. I was a little concerned about damage due to the soft packaging, but there were no issues.
Appearance: The chucks have a nice general fit and finish. The black oxide is dark and even and the machined surfaces of the chuck body are nice. The shank, collar, and OD near the ATC groove of the tool is ground with a fine finish. My previous import chucks had a rough grind to the collar that hits the nose of the spindle, but these new chucks were as smooth as my Tormach tools. The body, threads, and taper of the tool appear to be hard turned. This made me nervous, but shouldn't immediately disqualify precision since hard turning can be as accurate as grinding if done right. The taper had microscopic machining chatter marks (the kind that looks like a mirror shine until you pull out a magnifying glass) but certainly not anything significant enough to cause issues. The taper is smoother than the ground taper on my other imports, but I don't have a Tormach ER chuck to compare against. The threads are burr free and have no chatter.
The collet nuts have a lower quality black oxide and the information is laser engraved on the face. The threads and taper are again hard turned and look quality. Two nuts had poor surface finish/scoring on the taper (likely from a broken tool during manufacturing) and were set aside to be discarded.
Hardness: I used a fine cut file on the back of the holder, near the taper, and on the nut. The file skated across the surface without really biting but did not feel glass hard. I would loosely guess a low to mid 50's Rockwell C scale. A single nut had 5 hardness test dimples present on the face. I did not receive a chuck which had witness marks from a hardness test.
Taper Runout: Chucks were tested by rotating the shank in a Vee Block with a .0005 dial test indicator mounted magnetically to the block. I would have liked to use a .0001 dial indicator, however I did not have a way to measure the taper with this. An extra vee block was used to weight the shank down into the Vee to prevent error due to uneven pressure during measurement. The face of the collar was firmly pressed against the side of the Vee block during the test. This is necessary to keep the indicator in the same location in the taper, however any error in the collar grind will falsely show up as runout in the taper (due to axial motion of the chuck). Chucks and nuts were serialized. Runout was measured at 3 locations within the taper and an average is reported below:
  • Chuck 1: .0003” (.008mm) TIR
  • Chuck 2: .0003” (.008mm) TIR
  • Chuck 3: .0003” (.008mm) TIR
  • Chuck 4: .0002” (.005mm) TIR
  • Chuck 5: .0004” (.010mm) TIR
  • Chuck 6: .0006” (.015mm) TIR
  • Chuck 7: .0008” (.020mm) TIR
  • Chuck 8: .0008” (.020mm) TIR
  • Chuck 9: .0011” (.028mm) TIR
  • Chuck 10: .0012” (.030mm) TIR
Assembled Runout: Chuck assemblies were tested using a Techinks 1/4" Precision (.0002" TIR) ER20 collet and a 1/4" carbide dowel seated to full depth in the collet and measured at 3xD (0.75") from the face of the chuck using a .0001" Dial Indicator. The two nuts which were improperly machined were not tested to prevent damage to the collet. Additionally, chucks 7-10 were not tested due to the excessive taper runout. Each chuck was tested with each nut to find combinations that minimized runout. Understand that at least .0002" (if not more) uncertainty in measurement is introduced by the collet, wear on the collet, and the carbide dowel. Chucks were tightly to roughly equal torques, but I do not use a torque wrench, so some uncertainty is introduced there.
Runout varied from .0003" to .0026" with an average assembled runout of .0013". This leads me to believe that either the threads on the collet chucks, or the nuts have machining errors which cause the taper in the nut to assemble off center of the taper in the chuck. I was able to match nuts to chucks 1-5 which gave the following runouts:
  • Assembly 1: .0004"
  • Assembly 2: .0003"
  • Assembly 3: .0006"
  • Assembly 4: .0004"
  • Assembly 5: .0009"
Repeatability of these matched chuck assemblies unfortunately is not very good. For example, reassembling Assembly 1 yielded the following:
  • Assembly 1 Test 1: .0004"
  • Assembly 1 Test 2: .0012"
  • Assembly 1 Test 3: .0016"
  • Assembly 1 Test 4: .0006"
Customer Service: I contacted the seller of these chuck and stated that I had 5 units which did not meet their stated tolerance of 0.01 mm TIR. I explained my measurement method and the results I got. The seller was concerned that my methods may have introduced error in the measurements which was the source of the excessive TIR, but offered to send me 5 replacement chucks immediately. I have not yet received these in the mail, but I am very happy with this outcome.
Closing thoughts: All in all I am happy with the purchase of these collet chucks since my expectations were set reasonably. I have 5 chucks which I can (with a little trial and error) assemble within .0005" or so TIR. For me, having more TTS tools was more important than having 2-3 very precise chucks since I can create a library of pre-assembled tools that I can add to my CAM software. Since I won't need to take the chucks apart nearly as often to swap tools in and out, I can afford to take the time to assemble them for minimum TIR.
If you want less expensive TTS ER20 chucks ($20/ea vs $45/ea) and are willing to take the time to inspect the product and deal with some higher TIR chucks, then I would recommend this product.
I provided the above graphs generated by the servo drives to Warp9TD along with some of my troubleshooting analysis. Andy confirmed that I had found a legitimate bug which would be patched in Build 235.
Over the weekend I completed 3 additional tooling racks to match the one that already had made.
3 of the racks hold 12 TTS tools each and have .78" holes with a nice chamfer on the edge. The last rack holds 24 spare ER20 collets (.75") and 4 MT2 tools (.67") for the lathe. The MT2 holes are sized so the tapper cannot fully pass through the hole, this way my dead center can be held in there.
291756
291757
291758
291759
The material is black Sintra (recycled PVC) and is glued (PVC Cement) and screwed together. Very sturdy and will not mar the tools. The rack in the last picture has been used for 4 years.
Got the 5 replacement chucks from the post above. They are completely different from the first 10 as far as physical appearance. They are about 1/8" longer, have more black oxide, a thinner contact ring on the collar, and ground tapers. I think the physical appearance is a little worse than the other 10, but all ran true within .0003 checked at 3 places in the taper. I'm super happy. So now I have 24 ER20 collet chucks with maybe 6 or 7 that are only good for drilling or roughing tools.
Did a slotting test with a high performance endmill to see what it could do.
From Garr tool website:
Series VHM EDP# 49520
1/4x2" VHM HOG MILL *AlTiN
Solid submicron grain carbide end mill - center cutting
State-of-the-art rougher using Variable flute geometry
For stainless steel, inconel, pH materials, cold rolled steel, titanium, cast iron and tool steels
Furnished with a standard 45 degree lead chamfer
MFG recommended slotting data: 275-425 SFM, .0008-.0012 Fz, ap 0.5xD, ae 1xD
Material was a 1000 series cold rolled steel, 3/4" thick clamped in a 4" machine vise. Slots were taken along the X axis. I ran several tests but here was the cutting data for the most aggressive cut:
327 SFM (5000 rpm), 24 ipm, Total depth of 0.25" taken in (2) 0.125" passes. 0.83 motor HP required for cut, MMR = 0.75 in^3/m. Tool Stickout 0.38"
Machine and tool handled the cut very well. It was throwing small hot chips everywhere. I applied a small amount of coolant, but probably would have been ok cutting dry at the lower end of the tool's SFM range. I avoid slotting, but I think this tool would handle shallow slots no problem.
292307
292308
Note that the rough front edge of the stock was given to me that way., the witness marks on the first two slots 1/3 of the way in are from a previous pass taken by the tool, probably where the tool retracted.
292309
Tiny dark blue chips
HEADPHONES WARNING!!!
View attachment IMG_4544.MOV
