While you're waiting for PMDX to get on the ball, you could try unplugging the 107 board from the 126. Then see if you get the LED and/or 5VDC at P1-P14 when you toggle M3/M4.
Good idea. I'll give it a shot in the morning.
Not if you have P1-P16 set to PWM output. You could change your spindle speed and see if the voltage goes up or down.
Another test to narrow it down -
1. Leave the 107 unplugged.
2. Uncheck "disable spindle relays"
3. Set CW to Output 1
4. Set CCW to Output 2
5. Change Output 1 to P1-P16
6. Change Output 2 to P1-P14
7. Change Spindle on Motor tab/window - enable the spindle, but clear out the step/dir pins.
7. Toggle M3/M4 and you should get the two LED's on the 126 to light up.
This should emulate using simple on/off relays to turn the spindle on and off with no speed control. The point of this test is to try to force, in some way, P1-P14 to go high. Trying to check if you have a blown 126 board.
Update - Got the diagnosis from PMDX yesterday. According to PMDX the buffer chip that drives the P1 Pin14 signal has a dead output on that signal. They say this is unusual for a single signal on a chip to die, but it does happen. So all that testing we did and subsequent conclusions we made have been confirmed by the manufacturer. We were fighting a dead BoB.
The board is in the mail and should be arriving in a day or two. Hopefully I'll have my mill up and running early next week.
Back when I was working for a living, one output on a chip out of many being bad was the most common failure. They know their product better than I do, but that's my experience.
