- Mar 3, 2017
- 771
In case of a compressor, clearance space limits the compression in a single stage, and would beThe hole will have to be bored or reamed to get the finish needed for a cylinder wall. ,,,
As a practical matter a little extra clearance space at the end of the cylinder will not matter.
important to minimize. I'd consider machining a plug with one flat face, and fitting that into the
cylinder (secure with solder or braze, or pin...).
Finishing a cylinder wall can be done with grinding, or a hone, but reaming is more convenient.
I'm unsure that boring generates a good flat bottom, the center might not cut smoothly,
and of course the chip removal is problematic (could score the sidewalls).
Does anyone ever mill/bore with an orbital cut? Such as setting a boring bar for 0.5 inch diameter,
offcenter by 0.25 inch, and rotate the workpiece to make a 1.00 inch flat bottom?
