- Mar 31, 2015
- 318
Bore diameter tolerance is quite loose because I can make an appropriate size piston to fit the bore.You don't mention your tolerances. If the hole has tight tolerances, has to be straight all the way down the bore with a good finish and a really flat bottom then boring it would be the best way to do it. Given the depth and closed bottom, you are looking for a positive lead solid carbide boring bar.
