Really enjoyed your post, Rex. Well written and based on experience.
I thought tangential tool bits were pretty much just for shallow cut finishing work.
T15 is a Tungsten high speed steel that mostly uses tungsten for the hot hardness ability. It is an older design of HSS that is not often seen anymore, but I have some. M series HSS uses molybdenum for part of the tungsten amount for hot hardness ability. Molybdenum is cheaper than tungsten, so they moved in that direction. I have zero experience with using my T15 tool bits, but I assume that they perform pretty well. If you can get the end mill cheap, go for it...What is T15 and is it commonly used in cutters today? I'm curious because I came across a NOS Niagra T15 4 flute end mill with Weldon shank and a curious
ring around the end of the shank. Is T15 better than cobalt for lathe bits and other cutters? (sorry, not trying to hi jack, just saw a mention to T15 earlier in this great thread.)
Yes, I certainly was confused on that. I will look at your sources and educate myself. Thanks!Are you confusing a shear tool with a tangential tool holder?
Seems to me that for smaller lathes, you would want the flexibility to reduce cutting forces, no? To do that, you need to alter tool angles and this tool holder/concept will not allow for that.
The angles are fixed, but I use mine for both soft aluminum and fairly hard steel without issue. I'd probably use a different tool for turning a bunch of Delrin or really gnarly stainless, though. The amazing thing is you can even use it for threading. (The grinding jig lets you grind a 60º angle as well.)
It's not the only tool you'll ever need (you can't grind chip breakers, for example) but it suffices for about 90% of the turning and facing I do. It does tend to generate long chips, but then so do most of the well-ground tools I've made. I never grind chip breakers myself, anyway: speeds and feeds (and a pair of long nosed pliers) suffice for my needs.
