- Jul 2, 2014
- 7,594
I like the older HSS and brazed carbide bits better than the new ones. They seem to be higher quality. In HSS I like the MoMax best, and the Rex (Crucible), Morse, and Ludlum as well.
Also, I'm pretty sure old my lathe tops out at 500rpm in the top gear with the motor at 60hz. Even if I run the motor faster than rated i'm still barely breaking into carbide speeds. I think this really limits me to HSS.
It really depends on how big what you're turning is. SFPM is king. It doesn't take much diameter to make up for your lack of RPM.
Thanks for all the suggestions!
I would like to learn to grind my own bits....
I dug out all the bits in the box of stuff I got with the lathe. Here is what I currently have...
I finally got my 1946 15" Leblond lathe cleaned up and running. I have added a CXA QCTP with holders.
I'm planning to buy a set of HSS bits to grind to shape. How many and what size would you recommend as a starting amount for the different profiles.
I was thinking of 3/8 by 3/8 Grade M2 bits.
What would be a good starting set of bit profiles to have on hand?
Yes! I have a box labeled "dull/broken bits" where I toss anything carbon steel or better. Even an old spade style wood drill bit can become a useful tool of some other kind down the road. If you have family or friends in woodworking, construction, manufacturing, etc. you can ask them to save their "junk" bits as well. SDS-type hammer drill bits are particularly good as the shanks are very tough and the tips are often carbide. Once they round off that carbide a little they often get tossed. I've picked up several off of the ground at job sites (when I used to work in construction) so I can sharpen them into something else when needed. Tiny drill bits can become the knives in a shop-made wire stripper or the tip of a new scribe.Remember save all your broken drill bits, including center drills and tool bit stubs the are very useful for making boring bars.
