- Nov 14, 2014
- 851
Yep, your lathe predates SB's A, B, C designations. If I remember correctly, A is a gear change lathe, B, has automatic cross feeds (I think)' and C is equipped with a quick change gear box. So yours ( and my 1924 9x36 SB) are earlier models, with slightly different sized beds etc. but, essentially the same machine.
FWIW, I recently restored a smaller 7x36 Belt driven Dalton Lathe. I used a Napa, automotive sertintine belt for the back gear, and a simple V belt for the engine drive pulley. The serpentine belt works just fine. Quick to install, smooth running, and long lasting. Good to learn with and it will get you up and running quickly.
Glenn
Glenn
