- Nov 27, 2012
- 7,970
If you don't get flaking then you are doing good.
I knurl in one pass only, mainly to prevent work hardening in titanium but flaking as well. Luckily my lathe & knurling tool can handle it. Some machines can't so if you have a less rigid machine, you have to knurl with multiple passes. Especially with a bump knurler, I hate those things.
Soft materials like aluminum flakes very easy when knurling a full form & multiple passes, you will not see the flakes falling out of the wheels, they get stuck in the teeth & when rolled over they will embed into the workpiece. If you flood with lubricant you will see the flakes flushing out of the wheels. It's very fine, not like a chip.
Most knurling wheels that I'm aware of are HSS or cobalt. I use pvd coated cobalt wheels. I doubt they make knurling wheels in carbide but I have no idea.
Just to be clear, I'm talking about form knurling. Cut knurlers do produce chips.
