- May 18, 2021
- 51
I finally got everything together to take a shot at doing some practice turning. I knew from the get go that there will be a learning curve as with any skill.
I had difficulty to get the 1" 6061 to run true in the jaws. I did disassemble the jaw to verify that I had put it together correctly. One caveat is that the jaw I have doesn't have an ABC, only a "dot". I assumed that this is the starting point and worked from there. The jaws all meet when closed so I'll assume that isn't an issue.
I took quite a few conservative passes and the aluminum peeled off in long strands. Speed without a tach is guesswork at this point and I probably had it spinning slower than what it should spin. I used WD40 as a coolant and will look to different products if that is required.
I tried and failed at using the rear mount parting tool. I slowed the speed and fed very slowly but it jammed several times. Not wanting to do any damage or cause injury I stopped. Back to the books to see where I went wrong.
The pic makes it look worse than it is but the finish is far from what I think it should be. Any input will be appreciated.
