The Yeswelder CUT-65DS came in last Wednesday. I only had a chance to set it up on Friday and make a couple of test cuts. The test cuts went well.
Today I had a chance to spend some time in the shop and work on the mobile base I have been building.
I needed some brackets to weld onto the mobile base that I could bolt the casters onto. I bought a 14" piece of 4" x 4" x 1/8" tubing. I cut the tubing in half so I had two 7" pieces of tubing. Then I made the cut above with the plasma cutter cutting the two pieces into 4 pieces but tapered from 3" at one of the cut to 1" at the other end of the cut yielding the 4 brackets that I needed. With the help of a straight edge clamped on to the tubing almost all the cuts went perfect. The second cut I played around with the pressure and current a bit and the arc started going out after about an inch of cut. After a few more minutes messing around I decided to attach the ground clamp to the piece and the rest of that cut and all the other cuts went very nicely.
I did have a bit of slag on the cuts but I am new to this and haven't figured out the current and pressure settings yet. I made a test cut in a 1/2" plate which also went very nicely. All of the cuts that I made today were on 110v with a max of 45amps. The 110v/220v plug adapter they supplied does not fit my 220v shop plugs. I will have to make my own adapter.
As far as negatives:
The manual is for all practical purposes non-existent.
There is a flow gauge that came with the cutter which took me a while to figure out how to use it. At first I thought it was supposed to slip onto the drain port of the supplied filter / water separator. Then I figured out that you put the nozzle of the torch under the flow meter and adjust the pressure until the ball in the meter rises to the indicated marks on the flow meter.
The pressure adjustment and the pressure gauge mount to the back of the unit instead of being integrated into the unit like some of the nicer cutters. The pressure gauge points backwards so you have to turn the unit around or stretch your neck around the back of the unit to read the pressure gauge. I guess if you use the flow meter pressed against the torch nozzle you don't really have to look at the pressure gauge and the pressure regulator can be manipulated easily enough by reaching over the top of the unit.
Summary:
I am VERY happy with this cutter. It isn't a top of the line Hypertherm but it should easily handle anything that I will ever want to do with it including experiment with a DIY CNC plasma cutter some day. I doubt I will ever tax the full 65 amps the unit is capable of but it is nice to know it is there if I need it. That said there is nothing to confirm that it will put out 65 amps but there is no guarantees on the actual output any plasma cutter with the best hope that the big names are more honest than the cheap ones. I do have some gouging tips on order that I look forwards to trying to cut a few welds with. The replacement consumables haven't arrived yet so I can't confirm they will work. I will post when the arrive and I give them a try.
I have no regrets buying this cutter (so far). Everyone needs to make there own choices and I am no plasma cutter expert so I will not go so far as to recommend the cutter BUT I have found nothing that would make me recommend staying away from this cutter.
Cheers!
Edit: The S45 consumables came in today. They work fine. I do not understand the two Amazon reviews that say there are no consumables available for this plasma cutter. Maybe the description did not previously spell out that the torch was a Chinese clone of a S45 Hypertherm torch?
