- Nov 6, 2021
- 60
You are definitely over thinking the non-HF start. The term you should be looking for is 'Blowback' start. The way it works is that the electrode is attached to a spring. When the probe is off, the spring pushes the electrode into the tip, shorting out the Voltage source (which is off) to the return (the tip). When the PC fires, it turns on current to the electrode AND turns on the air to the torch. The air pressure causes the electrode to 'blowback' from the tip, thereby causing an arc which, with the high current source, soon becomes a plasma.
Tips & electrodes, both of which are consumed after a certain number of uses, cost about $4 each, depending on source and commonality of the components. Normally usage with very dry air will get you hours of usage. If there is any moisture in the air the consumables will be burnt out almost instantly. Net: Plasma cutting's 'invisible' cost is VERY dry air and lots of it. A $400 PC will require the same setup as a $3000 PC.
I don't have a TIG, but, from what I've heard, you can't use sensitive electronics while you're using one. But I haven't seen a CNC TIG welder either.
