- Dec 25, 2011
- 10,552
rfw_1968,
You didn't say whether the motor was connected for 120 or 240 (but given the motor specs, that doesn't really matter). You either have a bad breaker or a bad motor. If the motor doesn't get hot (not just warmer than ambient) after running for 10 minutes or so, it's more likely the breaker. Although it could also be an intermitten short in the motor. As you probably don't have a clip-on AC ammeter, I would change the breaker and see if the problem goes away. If it doesn't, something is wrong with the motor (or just conceivably with the lathe).
Robert D.
Robert D.
