- Jan 28, 2011
- 3,584
One thing that should said is to NOT adjust the load on the bearings when the machine is cold. As the machine warms up the bearings will be too loose, but again you really have to be careful if setting up the bearings when hot. They will too tight at startup. You want to adjust them after running the lathe for 20 minutes or so, not cold, not hot, just warm. After that you will have to run the lathe more to see how things go when it gets fully warmed up. You may have to back off a bit, if the bearings are too hot, or the opposite if the spindle gets too loose.
Check for runout and readjust to reduce to minimum without over heating the bearings.
Pierre
Pierre
