It is possible my arc distance was too long. I remember the arc wandering.
I think the key to all aluminum TIG welding is heat control. If you have a big heat sink as a work piece, you've got to get your foot into the pedal a bit, but as soon as (or before) it starts really working, you need to back way off the heat. If one piece is demanding heat and the other is blowing out, you can control the "dwell" of your weave to favor the colder side. Alloy is tricky, makes MIG spool guns really attractive sometimes.
I would start with a sharp electrode, pencil shape. If you have trouble with it not staying that sharp (like with thick 1/4" or more) then a more blunt angle but still sharp will last longer. A round or contaminated electrode will make the arc wander all over the place. Also use the shortest arc you can muster and closest to 90 degrees as posible.
Aaron
My guess on that joint is not enough heat? It looks like the filler is just piling up and not melting into a large enough puddle. Little penetration. That weld at the top is awesome!
Robert
