This time around the superglue I grabbed was Scotch "no run gel" and it seems to be holding up better than the runny stuff. Also it stays where you put it, on the surface. In the past I have had the normal superglue it run into the gap I want closed, which I think interferes with the skin's ability to close up, although I can't be sure since they did all heal over as I hoped.Glue is generally not recommended for high tensile areas with movement, like fingers but it may work for you. Be prepared to reapply... I actually prefer stitches so I don't have to worry about failure. The last time I put my fingers in the band saw, I glued the wounds closed. I ended up getting stitches two days later when they split open!
I sort of felt like the thin stuff was nice, cause I could sort of apply it like an eye dropper. But I’ll keep an eye out for that, and see how I like it. Thanks!This time around the superglue I grabbed was Scotch "no run gel" and it seems to be holding up better than the runny stuff.
