- Mar 26, 2018
- 2,719
Give the ground and honed carbide inserts for aluminum a try. They work pretty well from the limited experience I have with them. I also found isopropyl alcohol to be a great cutting fluid for sticky non-ferrous metals. My go to mix is 91% isopropyl + a bit of synthetic coolant mix + a touch of water soluble oil. I use this in a squirt bottle and it really works well.
Try a VCGT110302-AK (VCGT220-AK) insert in an appropriate holder. The "V" is a 35 degree diamond for low cutting forces and fine finishing. the "GT" and "-AK" indicates a ground/polished insert for non-ferrous metals, and the "110302" is a small insert, good for 1/2" or 3/8" tool shanks with a very small nose radius (again, low cutting forces for fine finishing).
I buy the cheap China knockoffs of these particular inserts and have had excellent experience with them. At $0.50 per edge or so, I am not afraid to try them on just about any material. I've done a bit of copper and gotten great finishes that have the rainbow light diffraction pattern on them right off the machine.
Also found a reasonably priced set of import PCD inserts in the same size.
Here is a RH holder, 10mm (roughly 3/8") square, at rock bottom import pricing. I've bought similar listings and have had no problems. Super cheap negative rake import tooling is a different story, but the positive rake tool geometry is pretty hard to mess up IMO.
I'll add that I love these inserts for fine finishing in non-ferrous, but also in 4140 (at higher SFM), and all stainless, especially 316. The insert life isn't very good, but they are so cheap and the finish they leave is amazing. I keep coming back to them. Think I bought 6 boxes in my last order.
10p VCGT110302-AK H01 CNC turning insert VCGT220.5-AK Metal Lathe for Aluminum | eBay
Find many great new & used options and get the best deals for 10p VCGT110302-AK H01 CNC turning insert VCGT220.5-AK Metal Lathe for Aluminum at the best online prices at eBay! Free shipping for many products!
www.ebay.com
2Pcs PCD Tipped Insert VCGT110302 Single Edge VCGT220.5 Polycrystalline Diamond | eBay
Find many great new & used options and get the best deals for 2Pcs PCD Tipped Insert VCGT110302 Single Edge VCGT220.5 Polycrystalline Diamond at the best online prices at eBay! Free shipping for many products!
www.ebay.com
1P SVJCR1010H11 CNC Lathe Turning Tool CuttingToolholder For VCMT1102 Inserts | eBay
Find many great new & used options and get the best deals for 1P SVJCR1010H11 CNC Lathe Turning Tool CuttingToolholder For VCMT1102 Inserts at the best online prices at eBay! Free shipping for many products!
www.ebay.com
