- Oct 29, 2012
- 1,392
I've been doing lots of research on machining copper in advance of a project and while I can't speak from personal experience, I can regurgitate what I've read in forums and from tooling manufacturers.
For your tool You want:
very sharp
Very pointy
High positive rake
Abrasion resistant.
diamond/PCD specifically designed for copper = best.
diamond/PCD designed for nonferrous metals = good
Carbide inserts designed for nonferrous metals or hand-ground Carbide of the proper geometry = ok
Generic diamond/PCD = somewhere between ok and crap
HSS hand-ground to the proper geometry = ok for a few minutes, then crap
Generic Carbide or HSS = crap
Use lubrication/coolant
Start with feeds & speeds for aluminum and adjust as necessary. There is also a document on machining copper from copper.org, but since the variants of copper machine so differently from each other and the cutter makes such a difference, the info is pretty vague
Those inserts for nonferrous and specifically for copper are hard to find and expensive. I've bought some from ebay, what I could I could find, and then bought insert holders to match what I was able to get. I haven't used them yet.
There are "free machining" coppers (ex: C14500 tellurium copper, and sulfured and leaded coppers) that are much less of a pain than pure copper. If you're not restricted to the exact type, check those out. You can buy c14500 from Saturn industries, that was the most reasonable pricing I found online. You may be able to find it cheaper from a local supplier.
very sharp
Very pointy
High positive rake
Abrasion resistant.
