The problem with any RTV, motorcycles have much smaller oil passages to camshaft and feed gearbox bearings/clutch.
RTV can and does, 'string' break off and block oil passages.
I generally use Threebond 1104, a non setting gasket sealer but I hear it's had a name change?
I've also used Blue Hylomar for years, it was developed by Rolls Royce and is also 'non setting'.
The idea of non setting sealers is, any that does drip into sump tends to stay there.
If it gets to oil pump, it smears incredibly thin, doesn't damage anything.
That doesn't happen with RTV as it 'strings' and does go through oil pump usually blocking oil feed to OHC/DOHC
In the past (1970's) I used RTV as I didn't know any better.
Never had a cam bearing failure but oil pump pick up usually had a few bits in strainer even though I was very careful not to apply more than needed.
I would never recommend RTV in any engine unless absolutely necessary (some area's on V-8's, corners of intake manifolds, etc)
As I have 50+ years experience building and modifying motorcycle engines (including in dealerships), I have seen the problems with RTV first hand on many many bikes and wouldn't use it on even a leaky old Triumph (and I worked at a Honda/Yamaha/Triumph dealer in late 70's)
