It was important to be to be able to retain the use of the carriage and cross slide locks, so this added a ton of complexity and time to the installation. My lathe uses these wing screws for the axis locks. They take up too much room so I created my own low profile version.
This consisted of a 304 stainless "hub" which was tapped to accept an M5 screw. The screw was glued in place with some Loctite green. I then cut the length of the screw to a precision value to the screw head did not protrude beyond 0.25" from the surface. I cross drilled the entire assembly to add a handle, then filed it to clean it up.
Here is the new lock installed.
I then placed the entire cross slide onto my G0704 to drill some mounting holes for riser plates.
These plates lift the scale away from the cross slide so the lock can be used.
Here is a mockup of the final assembly with the lock sticking out.
I also added a plate on the carriage to mount the read head. Thanks to the casting being unfinished, I had to machine, file and sand this piece into a angled mess to get the exterior surface sitting flat.
Due to the proximity to the ways and the length from the end of the bed, I was forced to drill the tapped mounting holes with this aircraft extension drill (which had the rigidity of a wet noodle). Drilling the two holes, opening them to size by hand, and tapping them took 3 hours and a lot of swearing.
I also wanted to make sure I could use the carriage lock. On my lathe this is a stud which protrudes out of the top of the carriage and is pulled upwards by tightening a hex nut. I replaced the hex nut with a slim 0.2" "nut" made from 440 stainless.
To clear some of the mounting features on the cross slide, the nut was machined into a tear drop shape on my CNC.
And a cross hole drilled and tapped on the small lobe of the tear drop to accept a handle.
Here is the piece installed. The threaded handle will be replaced by something prettier when I can go to the store next.
The stud was hacksawed off in-situ.
And cleaned up with a file.
With the scale installed, you can see why I had to be so careful with the vertical height.
At this point the cross slide install is done. The locks don't let me get as much clamping force on the axes as they did before, however it is nice to be able to snug them up on heavier cuts.
To be continued...
