- Mar 26, 2018
- 2,719
Nice work on your lathe. Just went through you entire thread. I have the Grizzly G9249 which is almost exactly like yours. I just ordered a DRO for my unit. Saves having to deal with backlash.
On the Cross Slide, did you use the cover for the scale or because it is upside down, did you not put it on. I haven't received my DRO yet but it appears to be the same scales, with a slightly different display. DRO
I assume you entered the different tools into the tool list on the DRO to make switching easier. ON other lathes I have used that function, I have found it necessary to monitor the inserts to ensure I account for wear and if I move the quick change tool post, I generally reset the tools in the DRO.
On the subject of replacing the single phase motor with a three phase. Have you looked into that? I would be concerned with finding one that would fit into the tight space I have on my Grizzly. Just wondering if you have already done the research and what you found?
I have the cover for the cross slide but haven't installed it yet due to pure laziness. I will have to cut a hole in the top for the cross slide lock so I'm not sure how much it will do.
This DRO doesn't have a tool table, but it has SubDatum Memory (SDM). This is sort of like work offsets in CNC, but on a lathe it is perfect for tracking tools. Just remember which SDM# goes with which tool. You would absolutely have to account for insert wear and I NEVER move my toolpost, even before the DRO.
I have not looked into the motor personally. I don't expect to have much trouble though. 3 phase motors tend to be smaller for the same HP, although I do expect I will need to adjust the mounting locations. You can always move the motor further back on the lathe and use a longer belt. Also your 3 phase motor won't have capacitors sticking off the top so it can be a larger diameter without hitting anything.
