Emco Compact 8 dimension request
Wow, you're making parts faster than I can measure them. Nice work.
FYI, my motor indicates 1700 RPM.
TomKro
Thank you :<) Excellent to know that about the RPM too!
Fermic, is that an inverter duty motor?
The one I have has a little bit more HP, but Class B insulation.
TomKro
Made some more progress. Found an old beat up tailstock from a 4th axis unit we mothballed and made some modifications! I need to tram both the headstock and the tailstock, I left room for that to do at another time, it's really close right now:<)
Good morning Gentlemen:<) Yes, I have another dimension request and even within 1/8 or so is just fine! I promise to entertain you with more pics as this project proceeds and it is moving along a lot better than I expected thanks to your help!! Attached is the drawing as I attempt to make the pulley support plate and cover:<)
THANK YOU :eagerness:
Here's my best shot for the dimensions. Hopefully I didn't mess up, but I advise you to lay out the dimensions on a sheet of cardboard and double check against the headstock as a sanity check before cutting metal.
Also be advised that the position of the intersection of the lower radius on the steel plate is really rough. I had no good way to check it.
Here's a link you may find helpful:
The site has exploded views of various assemblies, which may be helpful.
You sure are moving along quick. Keep up the good work.
TomKro
Thank you TomKro!!!!!! Can't tell you much I appreciate this!! And thanks for the link too:<) The lower radius will be negotiable as I have a different diameter motor any ways....adapt,adapt;)
Cheers!
