Well - good news; i tore the broken scale apart and found the tabs broken off. I was able to repair the tab that holds the spring thing that connects the reader head to the outside part with the circuit board in it. I mounted it back on the lathe and it's working now! Reads off by about a factor of 5 just as the other scale does.
I attempted to hook up the stepper tonight and after i had everything wired up i wasn't able to control it with the ELS. The stepper motor was locked up so it appears the controller is powering it.
Is it possible that the ELS isn't telling the stepper to turn b/c the RPMs are negative? What are the ideal settings for the stepper controller? Specifically S1, S2 and S3?
Great that you could repair the scale!
Locked does mean power. But not necessarily good. Could be that motor wires are not wired correctly. Or it could mean that S1 is set incorrectly.
To answer your question about RPM negative. The stepper will change direction if the RPM is negative, but that is desirable. RPM negative means the controller thinks the lathe is in reverse, in your current SW. The new SW will correct that and be + for forward, and - for reverse.
I will have to check the stepper motor controller settings. They are downstairs in the shop, so the settings are not at my finger tips. I looked them up. This is what I found...
S1 = C, I think, but I need to check on that.
For the moment, keep S1 at 0. 0 will not harm anything. However, it may not drive the motor, because of insufficient current.
S2:
SW1-SW4 should be set for 4 microsteps. SW1 = off, SW2 = on, SW3 = on, SW4 = on
SW5-SW8, should be all off, but I need to check this physically
Selector switch S3 = 5V this is important. We are using 5V signaling.
To confirm the settings, I need to open the control box on the lathe. I will do that tomorrow. I tried to see if I had taken a picture of the switches, but apparently didn't take a pic. I will take pictures and report back tomorrow.
You should be wired as shown in Figure 4, of the CLT57T(V4.0) manual.
