Take a look at this thread. I just am starting on my PM 1130V. https://www.hobby-machinist.com/threads/electronic-lead-screw.79812/
How does the Clough42 system work on these double shaft lathes? I have a similar Weiss 1127 lathe with the separate lead vs threading screw and i'm guessing that James didn't create the software with that configuration in mind. I was curious if it could be modified to have a different multiplier for feed vs threading or if it even matters at all.
You have PM.@ttabbal - I've begun the process of converting my similar machine to ELS equipped. The thread is here: https://www.hobby-machinist.com/threads/els-conversion-on-weiss-1127.103745/
I used a 4 Nm closed loop stepper motor from StepperOnline - https://www.omc-stepperonline.com/t...t-nema-24-motor-driver-w-2m-cable-1-cl57t-s40
It appears that you used a 2 Nm closed loop stepper similar to this: https://www.automationtechnologiesi...brid-servo-system/hybrid-servo-drive-kl-5080h
My stepper motor seems very weak, i can easily stop the carriage by putting my hand on the handwheel and offering a bit of resistance. The torque curves on my stepper motor seem to exceed yours at every RPM that is listed so i would think that it would work fine. In fact i have seen many folks use a 2Nm stepper motor without issues with the clough42 solution.
On my lathe the lead screw is 8TPI. The gearbox on my lathe is A - Direct, B - 1:2 or C - 2:1. The stepper does not like moving the carriage in setting B at all as it's overdrive, and will do it under low load for A. C is where i've been testing with it as the stepper doesn't labor as much. This means the stepper spins faster which should be less torque according to the documentation. It looks like you're gearing it down 2 or 3 to 1 by what i see in the pics whereas i'm running 1:1.
I'm trying to figure out if this is something specific to my lathe or something with the stepper motor/driver portion of the system. When i had the gear train setup on the banjo it seemed to feed just fine and the carriage travels back and forth fairly easily. It's not like it freewheels if i spin it fast and let go but i wouldn't call it hard to move.
Thank you in advance for any advice or thoughts you might have.
Yes we are PMing. Doesn't seem sensible that light pressure would do that, but on the other hand, I have not tried that particular test. Maybe I should try that tonight. My setup will cut 4 TPI threads in steel, using the identical motor, controller and power supply, so its not that anemic. But I can still stall it with some effort.We're private messaging each other - haven't found the issue but we're walking through it step by step to troubleshoot. I can stall mine and cause everything to need a reset by engaging the power feed at .0025"/rev and put just over light but not quite moderate resistance on the hand wheel.
