I'm wondering what hardware software combination to use. the original ELS project seems a bit long in the tooth. There are 3 or 4 on github and a Russian lead screw design.
I "need" a 1/2"-12 left hand thread. My lathe has no reverse so i'm thinking it would be just about as hard to do the electronic lead screw as it would be to add the reverse. I'd also need to make a thread dial. Changing the gear on that thing set is no picnic either.
I'm just started on page one of a 54 page thread that began in 2019.
I'll try to refrain from further comments along the way so there wont be an entire block of comments from me on this ELS implementation, but I do have one comment based on what Greenail said above.
Given the pace of technology options and upgrades to small consumer lathes and add-ons, it only takes a brief period of time for any project to become long in the tooth. People keep asking me why do I want to undertake an ELS project when so many exist and when I can buy Rocketronics version which appears to be the cat's meow?
For the doing and learning perhaps? Or more importantly, to attain features lacking in every other ELS project I see. I want a final project that mirrors the new smart lathes like the microweily TY-16SV and YUWE T5 series. Those are only available in 1640 and larger, I want them in smaller size.
I want encoder wheel inputs that act like normal hand wheels for manual machining but that activate stepper or servo motors on the appropriate axis. I need DRO output integration and I want ability to program simple operations at a GUI for turning tapers, balls, etc etc. I want to integrate grinding operations, and add the functionality I have with my current ESP32 based machining micro-controller that does my surface feet per minute and feed rate calculations. Basically, I'm saying I want it all, the deluxe model to make machining complex operations easy, without the need to have a cnc lathe i dont have room or budget for.
I plan on putting and ELS on my Colchester Chipmaster, my brother's Colchester Master 2500, and my buddies craftex 10x20. Quite the range of sizes.
I expect that in a few years time someone will say how long in the tooth my project is too... Hobby lathes will only come a smart lathes. Maker's will be integrating AI into their ELS systems so that you only need to scan a plan, or dictate the basics of how the part is to be made and dimensions and the AI will program the operations and make everything for you. Except you get to chuck the part, and say you made it.
