The easiest way to get a handle on that is probably to watch some YouTube videos showing really basic start to finish CNC stuff. It doesn't matter what kind of CNC. The basic process is the same, though the details vary..
You start with design software like Fusion360. Make a thing. It can be simple, think a wood coaster. Circle, extrude. Then you switch to the CAM process, take the thing and stock, determine zero points, and it figures out the movements. The output from all that is gcode.
Feed that gcode to the motion control system. And set the machine zero to the same spot as in the design. People usually use the top of the stock in a corner or the center. Much like setting your zero when machining. There are fancy probes and such. Can be helpful, but not required.
Hit go and hope you didn't mess up.
