- Oct 14, 2014
- 2,133
Woke up this morning and made coffee. A minute or so later - no coffee. breaker had popped and panel smelled of burnt electrical. reset breaker and it popped immediately. Not awake yet, just moved maker to another circuit. A while later there was another large POP. smoke out panel and small drink cooler circuit gone. Investigation showed this cooler was burnt out. A very short time later the circuit on the mini split popped and it was gone too.
Pulled VOA meter out and I had 160 volts on right sight power to ground and 105 volts on left side to ground.
Went outside to see if power voltages same at entrance, it was. Looked up and seen this:
So, pulled the mains and called the utility. They replaced the entrance cable and all is well.
EXCEPT we now got a dead ice maker, dead mini split, dead cooler. Is there any way we got a claim against the power company?
BTW here's the wires all but burnt through. How does one successfully file a claim?
