- Dec 18, 2019
- 7,497
Interesting. My glass scales were dead on, calibration wise. Tested against two 123 blocks stacked end to end. Also make sure you test return to zero. Use three 123 blocks. The first is clamped to the table. It is your zero point. With a DTI set it to zero (or some value that you write down). Set your DRO to zero. Add a 123 block to the table, against the reference. Move the table past the block and approach the new 123 block to the identical DTI setting. You always have to approach from the same direction, or you will not take up the backlash! It should measure 3.0000", or whatever you have measured your 123 block to be. Then add the third 123 block to make the length 6". Approach the part the same way you did the 3". Write down whatever value you get. If there's error, then you should have the values needed for correction.
Remove both 123 blocks and approach the reference block surface. Stop when the DTI setting is what you had recorded. The DRO should say 0.0000". If it does not, there's an issue.
When my mill scale failed, it would skip counts in one direction vs another. Screwed up a bunch of parts due to that. Cleaning the scale did not help. Cleaning the read head didn't help either. Replacing the read head fixed my problem.
