- Feb 16, 2018
- 29
If you use your 3 jaw chuck, I suggest you turn to the OD of the flange, then turn the smaller OD to size, then drill and then bore to final ID. Part it off a bit long and face the flange of the larger OD to bring it to final length. This will give you the best chance to keep the bore concentric with the OD.
If this is the first piece you are boring then I suggest you spend some time practicing. Boring is not difficult but there is a bit more to it than you might think.
Thanks, I will also no doubt be practicing a bit with the lathe. Luckily small lots of auminum bar is inexpensize. I have no doubt I may make a few mistakes. I've been around machining most of my life, but realize that's not the same as doing it. I'm here to learn, and do appreciate everyone's input.
