- Nov 14, 2016
- 3,332
Thank you all for the great replies and ideas!
I don't see anything like a RF 3x in my future, the price may be close but I can't imagine dealing with a 600-700# machine at this life stage.
After working with my DP the last couple days, I don't want to let it go. Not because I have so much energy invested in it, it's just so easy to use, produces great results, and it's paid for .
Let me refine my question a bit: would a mini-mill, like a Sieg X2D or clone, out-mill a DP regardless of how hot-rodded the DP might be?
Depends on what kind of work you do.
There is a wide range of small mills out there from really small to smaller than a Bridgeport. There are probably at least a dozen popular machines even keeping the weight to 350lbs or less.
If you mostly drill holes with an X-Y table, then a small mill may not actually do much for you.
If you choose a small mill that is too small for your needs, it may not be much if any improvement. Even if it is much better at milling than the DP it still does you no good if the work doesn't fit the mill, but it fits the DP.
I don't see any DP being better at milling than a mill that is properly sized to the work being done.
